Trims Posted May 16, 2018 Report Share Posted May 16, 2018 Does anyone know the correct Bosch number for an SDi coolant fan? The V Dub no. is 6N0 959 455E a 200/60w 2-speed as far as I can tell. The only Bosch one I've found is 0 130 107 291 which has two pins on the connector making it a single speed motor. My current fan as fitted (a Temic) has 3 pins as has the thermostatic switch on the radiator. Whilst asking, can anyone advise on the easiest way to get the fan out as it appears blocked by the top hose on the SDi? Quote Link to comment Share on other sites More sharing options...
mk2 Posted May 16, 2018 Report Share Posted May 16, 2018 what's the problem with the car? fans hardly ever fail on sdis.... Quote Link to comment Share on other sites More sharing options...
Trims Posted May 17, 2018 Author Report Share Posted May 17, 2018 Fan has cut in okay when stationary in traffic but made loads of noise. When the garage ran it up to temperature after radiator out for alternator change, they said it was noisy too! When spun over by hand it feels rough and graunchy. Nothing appears broken on the fan itself (curved blades) although it doesn't seem to have a balance weight/clip. Quote Link to comment Share on other sites More sharing options...
mk2 Posted May 17, 2018 Report Share Posted May 17, 2018 (edited) yeah, could be the fan motor bearing... not come across it in a post '98 car. older vdubs often. you can feel if the central shaft has too much slack by moving it from side to side. there should be no movement. there are a couple of people on here breaking sdis... Edited May 17, 2018 by mk2 Quote Link to comment Share on other sites More sharing options...
lupo 1.7sdi Posted May 19, 2018 Report Share Posted May 19, 2018 I searched for code 6N0 959 455E and found these codes Topran HP107717 Hella 8EW 009 144-611 TYC 837-0010 Thermotec D8W004TT Febi Bilstein FE10279 I did not find any code for bosch Quote Link to comment Share on other sites More sharing options...
Trims Posted May 24, 2018 Author Report Share Posted May 24, 2018 Thanks for the posts. Have managed to double check that my build against the vin is for a 200/60 watt fan. The Hella appears to be a 250/60 for a vehicle with air con (not available as factory on the SDi as far as I'm aware). Lots of the internet listings appear to be 'will fits'. The Febi Bilstein is specified as a 200/60 and appears to be able to be UK sourced. Quote Link to comment Share on other sites More sharing options...
Trims Posted June 17, 2018 Author Report Share Posted June 17, 2018 0 130 107 291 doesn't seem to be the correct Bosch listing. The one I've actually seen is a 2-pin. 0 130 107 283 might be the correct one. However it appears that both these have been discontinued by Bosch anyway. Found Murray's Direct at Hatfield a helpful and informative supplier. Quote Link to comment Share on other sites More sharing options...
Skezza Posted June 19, 2018 Report Share Posted June 19, 2018 Do SDI's even need fans? I can't remember mine ever spinning, even in red hot summers. Quote Link to comment Share on other sites More sharing options...
cj1 Posted July 2, 2018 Report Share Posted July 2, 2018 So if the SDI is supposed to use a 200/60 , does anyone know what a standard lupo would be? I changed the one that came with the 1.0 AUC engine (No A/C), to one from my SDI and noticed an increase in running temperatures. Interesting. Quote Link to comment Share on other sites More sharing options...
