VW CD player
matthewrspca
Bit of a daft question here, but the VW CD player that' in my car has a single CD slot on the face, but also has CD Changer option on it and for the life of my I can' work the changer. The manual doesn't help, so can anybody help me on how the CD Changer works.
Have you got a VW changer connected to it? I had a boot-changer in mine with the single cd player and you press the button on the front to switch between the 2.Only works with a VW 6 disc changer though.
rip out the boot mounted changer and fit a usb/sdcard reader dongle emulator (behind your head unit). the head unit thinks a changer is fitted and cycles through the files on the memory stick thing as if it was a cd... genious!!! and if you use a wifi enabled sdcard, you can update all the mp3 files when the car is parked outside your house :)
  • Thanks 1
