Olgis93
Lupo 3L TDI
Hi boys and girls.
New here ?
I have a lupo tdi 1.2L 3Lwith a bad gearbox i got in for free.
Im thinking of changing gearbox but to a ”fully automatic” gearbox. Anyone here knows if there is some gearbox that is bolt on to this one?
Thx for all answers ??
welcome to club lupo!
what is the problem you have with the gearbox? can you describe the fault?
Thank you!
5 th gear dosent work.
but i want it to be fully automatic couse here in sweden they count it as Manuel shift and this car is perfect for my mother and i love lupo but she can only drive automatic cars couse she only has it on her drivings license.
Why would they consider it a manual when it has no clutch pedal? It is fully automatic or semi-automatic, depending on the position of the gear stick. A manual it is NOT!
RAB
Ok for stooging about in though, only need 5th on fast roads... unless it has nasty noises in which case dont drive it.
Well in sweden it count as Manuel i dont know why. I dont want to fix it, you guys dont know any automatic  gearbox fit ?
The physicality's are easy, what are you going to do for software ?
I have a mechanic doing everything, thats why I need some help..
what software can i use and What gear box and so on?
Edited by Olgis93
The 1.2 TDi can be coded in VCDS to take a manual gearbox?
He doesn't want a manual box though....
i'll stick my neck out on this one, and say it is not possible to retro fit an autobox. well, not without a lot of work.
I've only ever seen 3L's converted to manual, never full-automatic...
All 3L's are fully automatic, or semi-automatic!
RAB
Exactly.
That's why I said the only conversions I've seen are from an automatic gearbox (standard) to a manual one.
RAB
All are originally automated manual, but the conversion to fully manual are relatively straightforward mechanically, as the 3L uses a manual clutch and gearbox.
I'm going to guess that a automatic conversion could be tricky. Finding a torque converter and automatic gearbox bell housing to bolt up to the 3 cylinder TDI engine block are the key. The rest should be relatively easy.
The 1.2 and 1.4 TDI in many ways is a chopped down 1.9TDI. I would start looking there for possible donors for automatic parts.
I would look into the world of A2 tdi.
but it isn't a simple task....
