41 minutes ago, OllieDewar said:
It's either that or an air horn..
I'd quite like to see a fog horn or ship horn or something just for utter banter.
But other than that, I just think Twin Horns etc are barry balls. Still, in answer to your question, it'll be easy as sin. Aren't most of them just plug and play?
Yeah pretty much. Depends on what type I guess.
I have twin air horns on the rally car and I used the existing horn connections to switch a relay, with power then going to the compressor.
32 minutes ago, OllieDewar said:
As far as I'm aware all I need to do is tap into the power from the first horn the power the second. Which will be easy enough with a couple of piggy back spade connectors.
Correct.
13 hours ago, OllieDewar said:
Installed the twin tones today, noticeably louder than the stock single tone and sounds a lot better. Mounted them behind the grill, Subaru style ;)
Subaru Lupo..... with the difference that the Impreza is so far in the distance and you're still trying to get up to 60 :)
I think he'd be doing 100 by the time I even got to 50. The 1l really isn't a performance machine
