Part numbers: coilpack, HT leads and brake light switch [Lupo GTi]
I'm going to buy the parts mentioned in the title and I've found the following part numbers in different threads:
Coil pack: 032 905 106 B
HT leads:
- Cylinder 1 - 036 905 430 R
- Cylinder 2 - 036 905 430 S
- Cylinder 3 - 036 905 430 T
- Cylinder 4 - 036 905 430 AA
Brake light switch: 7L6 945 511
I'm fairly sure the HT leads and brake light switch are up to date (threads dating 2015/2016), however unsure about the coil pack as that one dated back to 2008. Can anybody confirm if these are ok ar have they been made obsolete?
I'll answer myself as the parts have come in already:
Coil pack: 032 905 106 F
HT leads: as above
Brake light switch: 6Q0 945 511
Will try and fit all these sooner rather than later :)
Edited by Blue Loop
44 minutes ago, Blue Loop said:
Do you think it could be different because of LHD/RHD?
Doesn't list as LHD or RHD, can't see there being any difference to be honest!
5 hours ago, mk2 said:
in switzerland, are you allowed to fit non-OEM (not VW) parts like you can here in the uk?
We are! I like to keep mine as original as possible to be honest :)
Should I give it back and ask for the other part number instead or just try to fit this one?
