Electric Windows Question
Hi all, i need a bit of help and advice if you can.
The passenger window of  my 2002 Lupo wouldn't operate from the drivers side switch. On investigation I have discovered that for some reason, the wiring loom plug had been cut off and was obviously not connected to the switch.
I am curious  as to why this is has been done (?). Is  this a common problem with Lupo's or does someone  know where I can get a  replacement plug without going  to my local dealer? Thanks.
Pics?
You mean the wires are cut? Probably someone having a bad day with the window? Breakers for the plug and join the wires up again.
It's a small car you can lean over and use the passenger door switches though....
I've seen some butchery around this area before.
just go to a scrappy and find another door loom, plugs are in the footwell (three of them) and it is an easy job.
refitting is the reverse of removal as my Haynes once said.
