Landshark Posted January 23, 2018 Report Share Posted January 23, 2018 In a recent cold spell the missus went out to the car to drive to work and on starting the car the wipers failed to operate. She tried the stalk for the rear wiper and the screenwash but the stalk was completely dead. Immediately I jumped to fuse but it's unlikely that all three signals are on the same fuse (wash, front wipe and rear). I presume it's likely to be stalk failure but I can't imagine the switch being over CAN and failing the same as the Mk4 golf stalks have a tendency to. I'll check the fuses and relays tonight and then look at replacing the stalk at worse case. Anyone had similar before? Cheers. Quote Link to comment Share on other sites More sharing options...
JoeyEunos Posted January 23, 2018 Report Share Posted January 23, 2018 I had the exact same issue about 2 months ago, I made the same assumption as you. I'll save you the ballache and wasted time that I went through... It's all on the same fuse, replace it ? Quote Link to comment Share on other sites More sharing options...
