Leww_52
FFR Gearbox
Hi,
I am looking for an FFR gearbox for my 1.4s Lupo. I am finding it very hard to source one. 7
The issue with my box is that it has recon box in when i bought it. when i change into 5th gear, it is the exact same as 4th gear. therefore, it stays at the same RPM and screaming its nuts off.
any help would be greatly appreciated.
Lewis s
You sure the adjustment on the selector isn't out? Could be you are actually selecting 4th when it shows as 5th if its out of alignment.....
is this a common problem?
Wouldn't say it's common; but it can happen when you change the box. If the RPM stays the exact same it certainly indicates the selector.
How's your reverse?
How's your reverse?
the reverse seems fine! its hard to get sometimes but i thought nothing of it... im getting a terrible whine at the moment too, so i think the bearings are going also!
Can I remove my FFR gearbox and then refit it with a different code? As from my understand the FFR gearbox are very hard to get hold off...?
Sure. Replace it with any 085 box.
http://workshop-manuals.com/volkswagen/polo-mk3/power_transmission/5-speed_manual_gearbox_085/technical_data/gearbox_identification/code_letters_gearbox_allocation_ratios_capacities/
http://workshop-manuals.com/volkswagen/polo-mk3/power_transmission/5-speed_manual_gearbox_085/technical_data/gearbox_identification/code_letters_gearbox_allocation_ratios_capacities_2/
Find one you like the look of!
Are the polo boxes the same as the lupo? Thanks! what code would you recommend? i do not mind about what ratios etc, i just want a straight swap so i can use 5th gear again lol. also what gearbox codes go under the 085 spec?
Edited by Leww_52
085 is a gearbox type for a lot of VW's
Lupos, 6N Polos (tho earlier type 80 Polos also used them)
The differences between most of them is gear and final drive ratios, so potentially if you were to get one meant for a 1Litre Lupo when yours is a 1.4, it may end-up revving higher or lower in top gear, but it will physically fit your car.
So theoretically, I could stick any gearbox code in my lupo? All that's different is the ratios?
Yep
17 hours ago, cj1 said:
Yep
super! Thanks for your help mate! much appreciated!
No worries. Let us all know how you get on! :)
