hoddlewaddle
1.4 16v subframe
Considering fitting a 1.4 16v in the current 1.0 - let's not get into the whys and wherefores, it's a project for the two of us...
Until I get one in front of me to compare, I'm not 100%, but is the subframe the same and the bolt-on mounts different... or do I need the full frame?
I understand the Sport hubs are different and enable the fitting of proper sized brakes - how much else is different chassis-wise between the Sport and a boggo 1.0?
Rear end comes with discs IIRC? Naturally I'm concentrating on the important bits (that make noise) first.
(If I've missed a very obvious topic, please feel free to insult me and direct me to it...)
This is the only thread I can find on here discussing subframes.
I suggest you ask @Rich.. he is a wealth of knowledge :)
  • Subframe is the same. Only 3 that are different are the GTI, 1.4TDI and the 3L.
  • Sport hubs are different yes. Rear beam is also different as you mentioned as they have the discs on. But you can change from the stub axles outwards to convert the drums. Handbrake cables are slightly longer for discs on the back too.
  • Engine mounts are different obviously too.
  • Everything else "chassis-wise" is the same.
That is spot on - thank you! Much appreciated.
Now to make the world's largest order of Plusgas and wire brushes... and of course a couple of new hammers.
