Low N' Slow
Emissions fail
Hi guys, I have a 1ltr Arosa. I squished my cat on a speed bump ages ago, I've not been able to afford a new cat so I put a straight pipe in it's place. I therefore had the 02 sensor cut out for the time being. As my car has an engine management light because of it, I was hoping having that deleted would help it through MoT (lol). It just wont go through emissions by literally 1 or 2 numbers!
Anyone have any ideas how to sort or if anyone has had a straight pipe in place with no issues? I'm thinking I may have to replace it with a new cat with the 02 sensor back in it, and maybe remove centre box and have the straight pipe there (for noise, otherwise I over rev then hear the car LOL) But this is obviously a more costly way. I wanted a sports cat but couldn't find one for it! Had sports cats before with no issues. It's currently waiting to go back in for re-test soon as I can think of the cheapest way for me (unfortunately).
Couldnt you fool the ecu just with resistors on the lambda? Dont know, only dealt with diesels for years now tbh.
friendly emissions tester.
As above, mine failed once so the tester hooked up his bosses brand new jag. Still failed...😂
  • Haha 1
used a 1999 rover 75 yesterday...
straight through from cold.
Thanks Sausage I'll see if I can do that!
Lol I'm not sure if I can 😔 I was kinda hoping that they could do that lol. An annoying little thing stopping it pass... sods law 😂
Thanks for your replies guys!
you have to weld one in or find an independent friendly tester.
I knew you got a dirty ticket...
  • Haha 1
you should hear the exhaust.
  • Haha 1
Thank you for your replies everyone 👍I will see what I can do! The fact it's only just failing by a smidge is a pain lol. No other holes in my exhaust system either 🙄
chuck a rag over the end!
I've seen some magic rags on emissions testers.
you travel for yours?
i wouldn't use anywhere else.
you know of the tip jar ?
I'm conscious of the tip jar and always round up to £40 (£5 tip).
Pretty much the done thing isn't it?
£40 is standard.
Jinner likes to holiday in the Algarve.
😂 thanks for the replies! I shall try and work some magic myself, flutter my eyelids and all that jazz 😜
are you female?
you should not be having a problem with this!
18 hours ago, Rich said:
£40 is standard.
Doesn't surprise me in the least, he has the air of a cosmopolitan well traveled type.
Ever used the workshop round the corner? I get them to fit tyres when needed, very affordable (£6 a corner). The other chap who works in there's a real character too.
bob? He likes blue roll.
i have used it, couldn't be arsed to do the sdi (red one) clutch, they did it for £100.
i often use it for other peoples cars. :)
mot welding, my mate uses them to keep his £150 Micra alive.
On 21/10/2017 at 4:33 PM, Rich said:
are you female?
😂 yes I am female!
I've been told it's due to the 02 sensor. So adding it back in to the straight pipe still may not work... and also been advised a rag won't work in my situ (due to the fact it's the main 02 sensor being absent, not the one by manifold). I may bite the bullet and replace with a new cat - and have the straight pipe replace the centre box instead. I'm used to louder cars, the Arosa has a very quiet engine so I stall as can't hear the revs 🙈😂 I usually claim it's because I'm a woman driver though, I can use that to my advantage sometimes lol 😉
All of a sudden I'm more interested. :)
age? Stats? More details in general. :ph34r:
back to the car, yes you should probably just buy a cat and a lambda, sling it back in and delete the backbox for the same noise.
Hahaha! In my 20s...nearing the end of them anyway 😲
Yes I've decided to do just that Rich! I thought maybe chuck the straight pipe in place of the centre box. Would that make enough noise too?
I am tempted to replace the back box. Though only had a new one 6 months ago 😂
After 2 years of ownership I should really know my car better.. but this is my little cheap runner whilst saving to work on another car 😉
