Sausage Posted September 30, 2017 Report Share Posted September 30, 2017 Having a job finding anyone selling cheap syncro kits and parts for the 02J box. Plenty selling rebuild kits which are just bearings and seals, I need a spring clip and maybe a syncro as there's a broken syncro spring on 3rd/4th gear which is just a metal spring clip worth pennies like in this pic: I'll probably end up buying spares or repairs box and raiding it for bits at this rate. Have a box lined up for the red TDI, this is just to satisfy my curiosity tbh. Quote Link to comment Share on other sites More sharing options...
Sausage Posted October 2, 2017 Author Report Share Posted October 2, 2017 http://www.ebay.co.uk/itm/Z-End-Inner-Cable-Piano-Rigid-Wire-2500mm-x-1-5mm-For-Cable-Repair-On-Lawnmower-/261598733487 Will make one instead. I scrapped a piano last year and chucked all the very springy steel wires because i couldnt see a use for them.... Quote Link to comment Share on other sites More sharing options...
DeanH Posted October 2, 2017 Report Share Posted October 2, 2017 Could you get one from a bearing supplier? I imagine they will stock retaining clips. Quote Link to comment Share on other sites More sharing options...
Sausage Posted October 2, 2017 Author Report Share Posted October 2, 2017 (edited) probably get them from main dealer but having seen some single synchro springs for £15 for a Vauxhall and me needing 2 of them I bought some spring wire instead as these arent a complex shape. Not sure if they broke pulling the gears off or that is the reason 4th gear was such a b4stard to select when driving it, but i couldn't move the synchro by hand to select either 3rd or 4th prior to pulling the gears off the shaft so something wasnt right there. have just found these now but would need to confirm size is the same: http://www.ebay.co.uk/itm/TYPE-9-FORD-3rd-and-4th-GEAR-SYNCHRO-HUB-SPRINGS-/311653986470 (just messaged them for 02J) Dont mind chucking a few quid at it, but around £40 is the cut off zone tbh. Synchros are probably all right, ideally needs a couple of bearings while i'm there. Edited October 2, 2017 by Sausage Quote Link to comment Share on other sites More sharing options...
Sausage Posted October 4, 2017 Author Report Share Posted October 4, 2017 http://www.allcarpartsfast.co.uk/vw-audi-seat-skoda/vw-audi-seat-skoda-088311311d-spring/ Basically £1 each (plus delivery), that will teach me. Quote Link to comment Share on other sites More sharing options...
Sausage Posted October 5, 2017 Author Report Share Posted October 5, 2017 (edited) While waiting for the VAG springs to turn up a few mins of twiddling with the spring wire yields these beauties: Needed the ends bending a bit to make them do their job properly... Both 3rd and 4th synchros are knackered though... Cant justify £60 on them plus any other bits so this box is for parts... Edited October 5, 2017 by Sausage Quote Link to comment Share on other sites More sharing options...
