AlexHardy91
1.7sdi turbo?
Just pondering about a 1.7adi lupo. I'm going to look at one today. Would the manifold and turbo from my spare ahu engine go onto the sdi? Would it take much to get it running right? I'm thinking manual boost control valve, bigger injectors, oil feed and return and a clutch upgrade? Anything else?
Edited by AlexHardy91
I'd like to see this done, not sure how much the ecu does on the SDI, if it is reading maf and map and IQ then you will need a remap.
Also intercooler.
go for it!
11 minutes ago, Rich said:
go for it!
Also intercooler.
 Could just drop the full ahu in there I suppose like. Won't be for a while yet like. I still need to finish my mk3 wagon
you need to turbo the sdi to finally answer the question.
It's been done before.
TDi forums about 1.9 sdi:
Originally Posted by turbo johan View Post
I've done quite some of this kind conversions.
Easiest is to put on a GT15 wg turbo from a AHU/AGR and put wg on about 0.6/0.8 bar boost.
Run no ic and put in some new sw.
Power goes from 68 to 100/105 hp on stock injectors.
You don't need boost regulation or a MAF an MAP sensor.
Works good.
If you want more than that you need different gearbox and flywheel/clutch!
I've done a few sdi/tdi gearbox conversions works quite good but need some parts; axles, fw/clutch, box, shifting cable, conversion to hydro clutch pedal or use T4 clutch cable. (but clutch pedal won't fit cable easy).
My girlfriend drives a sdi polo who drove the 105 hp easy conversion for about 40K km's.
Than we did VNT17, R520, 11mm, longest 5 speed gearbox, stronger clutch with smf, 2,5" exhaust, 3 bar MAP and custom tune.
It runs on 190 hp and 450 Nm now.
It ran 14.5 sec 1/4 mile @ 155 km/h (with 175 hp w/o 11mm pump)
I just wired up the N75 and MAP sensor into stock ECU works fine.
Johan
cant find any 1.7 conversion though or Lupo so far.
Edited by Sausage
