Sausage
VED band and engine conversions
Got a 2nd Lupo TDI with £30 tax now and looking for some confirmation of what happens to VED after an engine conversion before i go down that road with it.
I have seen conflicting info on this so far, but so far I think it stays at £30 as that is what is on the V5C as the emissions band regardless of what i put in it. (unless electric and i want an inspection to get it to £0 tax i guess)
Sooo, if i stick a 4 pot tdi or a 1.8T etc in it, will that **** up my £30 tax band?
Edited by Sausage
Yes. It will **** up your 30 pound tax
was it the modified red one from Rhydamman?
Indeed it was. £215 quid with £200 set of wheels in the boot as well. I gave him £220 as I felt bad. :lol:
Gear selection dodgy, make that extremely dodgy (will look at turret) massive amounts of camber with knackered front wheel bearings (no surprise there), knackered front drive shaft (due to previous silly lows and hitting chassis), brake vacuum had a mind of it's own.
Just looking for clarification on the tax front before decisions get made.
Edited by Sausage
Can you be more specific as to why you think so? I'll probably have to contact DVLA and ask them about this but I  have a strong feeling I'd get a different answer depending on who I spoke to.
Ok I have the answer as I just phoned DVLA, it reverts to pre 2001 method of engine size under or over 1549 cc so  £150 or £245.
Bottoms.
Because of the reason the DVLA gave you.
Hence chavs tend to do 'undeclared mods innit bruv'
Only slow internet stopped me from bidding, I had been to look at it a couple of months back when he had it up for sale then and agree about the faults, which also made it impossible to test its performance but the artwork is very good and worth saving for that alone
Yes shame about the tax, for some reason that option never even crossed my tiny mind, but they have to really as they cant assess the emissions on a conversion so just default back to basing it on engine size. :(
Yep I can see the appeal of not declaring a 1.9tdi now but a dim view would be taken of the VED fraud if found out so that is not for me.
The car is ripe for a conversion due to all the faults on it, but it would be a waste of the car to do that given the tax hike and the tdi USP of £30 tax. Will have a think, but probably just end up repairing and driving it as it is a better shell than my black one and will look out for a cheap petrol Lupo now for a silly conversion.
It's slower than my black one by a long shot btw.
Edit: found boost leak and vaccum leak today so not a fair comparison tbh....
Edited by Sausage
Sooo now a small part of my tiny mind wonders what happens if I (was stupid enough to) tell them I have changed the engine to another 1422 CC TDI engine and provide proof it came from an audi A2, a Seat Arosa, a Seat Ibiza, a Skoda Fabia or another Lupo TDI.
Would that default to £150 tax as it is a change of engine? Just covering my bases here....
Edited by Sausage
just insure it as whatever you make it and pay £30 tax, plead ignorance if stupid enough to be caught out
i have an ajm diesel conversion sitting there which i will part with cheaply. (£200)
If you are refitting another 14 TDI engine why would you even tell them?
Me personally, i wouldn't bother if it's like for like, or close enough, but you are supposed to tell them about  any engine changes including engine numbers etc so my question was if you told them even though they are the same engine  would that bump the tax to £150? It should following their "logic".
Man my avatar is annoying, changing it now...
Edited by Sausage
just buy my ajm already!
Shan't.  It has one too many cylinders.
What 1.9 gearboxes go on the 3 pot? And what would fit in lupo?
no idea.
02j?
Just want one that can take a 4 pot flywheel and clutch for now, so if my 02J can i'll stick with that.
I have an 02R box here as well off a BNV.
you're not going to put enough power through the thing to take the standard clutch out.
They slip when the torque gets much beyond 250nm and heavy duty clutches are slim pickings and expensive for them, 4 pot flywheel and clutches gives bigger clutch and cheaper HD options.
I think the 138HP one on here a few years back used G60 flywheel and clutch and standard 02J box if I remember right so I can make do with just flywheel and clutch.
http://forums.clublupo.co.uk/index.php?/topic/78710-seat-arosa-14-tdi-1749v-138-hp-212-lbft/
Edited by Sausage
why tune a 75bhp when you can put a 150 in and move from that?
start big.
I like a challenge, i retain £30 tax without having to duck and dive, plus it will handle better with a 3 pot.
Will probably do a 4 pot at some point though.
