wehey
Seat Arosa 1.4 Tdi For Sale
I have for sale my lovely Seat Arosa 1.4 Tdi
I have had the car for nearly a year and have carried out loads of work to make it the great car it is today.
It's cheap to run and I get 60mpg all year round and only £0.08p per mile (see attached photo proof)
Only £30 road tax and cheap to insure.
It does have a remap to 110 hp but I can put the standard 75 hp map back onto it if you want.
Current mileage is 131K but these engines are fantastic and easily make it past 200K without problems. Just change the oil religiously every 7K and it will last you forever.
It has a Full Service History up to 126K which is when I got it.
Since then I have done the following:
2x New Wings
Oil/Filter change @ 127K
Diesel filter changed
Diesel purge
New air filter
Coolant changed
Gearbox oil changed
New clutch in July 2017
Underside wax-oiled including real axle and front subframe and rear side of new wings.
2 x new lower suspension arms (front)
New anti roll bar bushes
2 new front tyres
Rear tyres >5mm
Remap to 100hp
60mpg + (see attached photo)
£30 road tax
Cheap insurance
New stainless front de-cat
MOT until Feb 2018.
Passed last MOT with NO advisories
Service history up to 126K
Cam Belt changed at 103K
A few points to mention.
The switch on the driver side that operates the passenger window only goes up and not down although it work fine from the passenger side. I have a spare switch that is simple to fit.
The clutch is brand new but very, very occasionally you can hear the release bearing stick on the gearbox input shaft and you hear a small rattle. Dip the clutch and it goes.
This is not a problem and shouldn't be a concern.
Front brake discs are slightly warped which you can feel through the pedal when braking hard. It went through the MOT fine like this.
I have tried to be as honest as possible. I know this car inside and out as I do all my own mechanics. It will make someone a great cheap runaround.
I think it's very well priced at £750 and has to go soon as I have just brought a new car.
2x New Wings
Diesel purge
New air filter
Coolant changed
Gearbox oil changed
2 new front tyres
Rear tyres >5mm
Remap to 100hp
£30 road tax
Cheap insurance
MOT until Feb 2018.
Was that an app or something you were using??
