arosa mid (or hi) fi
hi all.
the goal is to build (the faster the better) a 3 way system plus a sub in the trunk on my arosa. to be fair i spotted some fine works here, thus i decided to place a 2 way on the dash with home-made pods for a Ciare CT250 and a CM501, to keep the midwoofer in the door (Ciare CW 161N) and place both subwoofer (Coral Target TLS 12) and the amplifier (Zapco ST-5X) in the trunk. the radio is a Kenwood KDC-X5100 BT.
the subwoofer came with a project of 32 lt closed box, very close to the volume of the spare tyre area. that's why i decided to follow that way.
here are some pics, more to follow.
cheers,
guido
Edited by sintoni
info added
ty mate. now working on a spare dashboard: i'm gonna keep the single midwoofer in the doorcard, yet i wanna put a 2 way system to improve the soundstage. i have to do some empiric test and choose between a dome midrange and a dome tweeter (hpf 1 khz) or try and fit a quality coax (focal 130 ac, hpf 250 hz). both are good choices but they need a different amount of job: stay tuned and cheers from italy ;)
  • 3 weeks later...
At last, I decided to place two cone midranges on the dashboard (Hertz HL 70) and four 6,5" woofers (Electronic Melody MCW65N) on the doors (two per card).
The tweeters are two Ciare Planet CT 250; the subwoofer is a Coral Target TLS 12.
Tweeters and midranges need a passive crossover I'm gonna build; everything else has an electronic cut (approx 80 Hz sub - 300 Hz woofers, to be decided during the set-up).
Edited by sintoni
Damn, this worth a drive to Italy for you to do mine! Love it!
Edited by lupogtiboy
Mounted everything on the standard door card: I had to use some fiberglass (over acoustic carpet) to close the gap (the door cards are not plain). BTW, the left pod is about to be carpeted in black leather by a pro. Meanwhile, the pods for midranges and tweeters (and the one for two gauges) are about to be sprayed.
IMG-20171020-WA0279.thumb.jpg.166f5be9c79dc534f03d0670adbb8f29.jpgIMG-20171020-WA0278.thumb.jpg.8321ae8686017681b7f733410417b457.jpgIMG-20171020-WA0277.thumb.jpg.851e02f38894c18d8f0c71a960592f39.jpgIMG-20171020-WA0276.thumb.jpg.531c304a687b8b788c6a7e2a2fcbc0a9.jpgIMG-20171020-WA0275.thumb.jpg.47ad62db1da66c86e54e793d438ff0ba.jpgIMG-20171019-WA0154.thumb.jpeg.44630c648d94c0d3655d3b1997ade75c.jpeg
