Atops Posted August 17, 2017 Report Share Posted August 17, 2017 (edited) Hey so i have a X plate (2000 year) Black Lupo and i was wondering what wheels would look good that don't cost too much (I'm not ratting it). I have put a new steering wheel in it but it has no Airbag so for it to pass an MOT and be road legal would i need to have harnesses to keep the wheel in? I also need 3 locking barrels for all three doors of course but need the key to math as well. When taking the plastic trim off the outside of the car what is the best way to get the adhesive residue off without damaging paint. Many Thanks. Edited August 25, 2017 by Atops Quote Link to comment Share on other sites More sharing options...
FlipFlops Posted August 22, 2017 Report Share Posted August 22, 2017 Have you got an Airbag light on the dash? As far as i'm aware, fitting an aftermarket steering wheel isn't an MOT fail but the Airbag light on the dash if lit up, is a fail. Not sure on the rest tbh. Does your key not open the doors or are the barrels damaged? Quote Link to comment Share on other sites More sharing options...
cj1 Posted August 22, 2017 Report Share Posted August 22, 2017 No, as above, so long as the airbag light isn't on you have nothing to worry about. 3 options essentially: Strip cluster down and desolder LED light Strip cluster down and tape over LED light Use a resistor to trick the light into thinking all is OK. As for the adhesive residue, I used Petrol. Worked a treat. Quote Link to comment Share on other sites More sharing options...
cj1 Posted August 22, 2017 Report Share Posted August 22, 2017 And the locks, find a breakers, get them from there. Why do you only need the 3 and not the key barrel for the ignition? Quote Link to comment Share on other sites More sharing options...
Atops Posted August 22, 2017 Author Report Share Posted August 22, 2017 2 hours ago, cj1 said: And the locks, find a breakers, get them from there. Why do you only need the 3 and not the key barrel for the ignition? I'm not too sure why but all the door except the drivers side don't work. Boot door wont turn so i think it may be a different key needed. The passenger side turns but doesn't do anything. I use a different key for the ignition so that works fine. Quote Link to comment Share on other sites More sharing options...
Atops Posted August 22, 2017 Author Report Share Posted August 22, 2017 2 hours ago, cj1 said: No, as above, so long as the airbag light isn't on you have nothing to worry about. 3 options essentially: Strip cluster down and desolder LED light Strip cluster down and tape over LED light Use a resistor to trick the light into thinking all is OK. As for the adhesive residue, I used Petrol. Worked a treat. I've tried the resistor but it hasn't worked. Quote Link to comment Share on other sites More sharing options...
Rich Posted August 22, 2017 Report Share Posted August 22, 2017 location? i do a lock barrel rebuild service. Quote Link to comment Share on other sites More sharing options...
Silver! Posted August 22, 2017 Report Share Posted August 22, 2017 2000 - 34 plate? ? Where I went to school a 2000 would a W or X plate ?? Quote Link to comment Share on other sites More sharing options...
cj1 Posted August 23, 2017 Report Share Posted August 23, 2017 It's one of the future editions Quote Link to comment Share on other sites More sharing options...
Atops Posted August 25, 2017 Author Report Share Posted August 25, 2017 On 8/22/2017 at 5:36 PM, Rich said: location? i do a lock barrel rebuild service. Ellesmere, Shropshire Quote Link to comment Share on other sites More sharing options...
Atops Posted August 25, 2017 Author Report Share Posted August 25, 2017 (edited) On 8/22/2017 at 7:51 PM, Silver! said: 2000 - 34 plate? ? Where I went to school a 2000 would a W or X plate ?? Yeah sorry X plate. Edited August 25, 2017 by Atops 1 Quote Link to comment Share on other sites More sharing options...
Atops Posted August 25, 2017 Author Report Share Posted August 25, 2017 On 8/23/2017 at 8:50 AM, cj1 said: It's one of the future editions Shhh, it never happened 1 Quote Link to comment Share on other sites More sharing options...
