Lupo Alarm and Lights
Old Timer
Hi Lupists,
I've noted that the security light on the drivers door does not does not flash when the car is locked, and so I have tried rocking the vehicle which is not setting off an alarm. Any experience around faults here? Also (as it's unclear from the book), is there meant to be a "lights left on" warning if you try to leave the car without turning them off... I ask as I have run down the battery twice with not noting the dash lights were on in the early evening... If there is not one factory fitted (which would seem strange for VW in 2005), has anyone got experience of retro-fitting a lights left on module?
Thanks for reading!
Hi Rich,
Thanks for the reply, much appreciated!... "door switch" as answer to security, lights on or both? I note the interior light is switched by a door switch, so not quite sure which one you mean? Thanks for taking the trouble.
