Karlos Smith Posted July 30, 2017 Report Share Posted July 30, 2017 I'm looking into getting my first VW Lupo 1.4 I been looking around and wheels & found a pair that I think will look amazing (shown in picture), They are 15" 8J 4x100, will I need to roll the arches to allow for these wheels? also looking to fit lowering springs, 60mm on the front and 40mm on the rear as they come in that set, are they easy to fit or am I better off going to a garage? Quote Link to comment Share on other sites More sharing options...
Silver! Posted August 4, 2017 Report Share Posted August 4, 2017 Springs are fairly easy to swap, but for the front you'll need a set of spring compressors and a deal reach 21mm ring spanner; or spark plug socket is what I used with a spanner on the flats. Rears are a piece of piss. ..a small garage will likely charge you £100 Quote Link to comment Share on other sites More sharing options...
Silver! Posted August 4, 2017 Report Share Posted August 4, 2017 - photos are gone, but it's a detailed description. Quote Link to comment Share on other sites More sharing options...
T3LLIOTT Posted August 4, 2017 Report Share Posted August 4, 2017 Pretty sure you'll need to roll the arches at that height not only for clearance, but (offset depending) these wheels will more than likely poke out of the arch (technically illegal if not covered). Quote Link to comment Share on other sites More sharing options...
