dacca Posted July 26, 2017 Report Share Posted July 26, 2017 Needing help! I have a 1.7 SDI and have a issue which is that it will not start , I put key in turn and have no glow plug light , before it refused to start it would take up to half an hour of turning the key on off on off waiting for the glow plug light to come on when it did flash on it would start straight away no issue and when started had no problems ie didn't cut out etc but when turned off whether it ran for 5 minutes or 5+ hours it would still take just as long to start. Now I'm getting no glow plug light come on, now I have changed glow plugs, glow plug relay, fuel pump relay , have had it on a computer and not showing any issues gone through all wire's and connection and all OK and have changed little black immobiliser box that Connect's to the key reader and still nothing. As you can guess I'm a little stuck as to what it might be know its something simple please any ideas would be appreciated . forgotten to say that the car still turns over just doesn't fire up. Thanks for reading Quote Link to comment Share on other sites More sharing options...
Skezza Posted July 27, 2017 Report Share Posted July 27, 2017 Relay 109 Quote Link to comment Share on other sites More sharing options...
Rich Posted July 27, 2017 Report Share Posted July 27, 2017 wire break if that doesn't work. Quote Link to comment Share on other sites More sharing options...
JoeyEunos Posted July 27, 2017 Report Share Posted July 27, 2017 40 minutes ago, Skezza said: Relay 109 This. The fact the glow plug light isn't lighting up and when it does it starts is what's known as 'a clue' There's an upgraded part no on the basis the original ones were so troublesome. Call VW, shouldn't cost any more than £20. Quote Link to comment Share on other sites More sharing options...
The Penguin Posted July 27, 2017 Report Share Posted July 27, 2017 battery ok? Quote Link to comment Share on other sites More sharing options...
Skezza Posted July 27, 2017 Report Share Posted July 27, 2017 4 hours ago, JoeyEunos said: This. The fact the glow plug light isn't lighting up and when it does it starts is what's known as 'a clue' There's an upgraded part no on the basis the original ones were so troublesome. Call VW, shouldn't cost any more than £20. The upgraded part can also be had from ECP for quite cheap. It has all the hallmarks of 109 though. No Glow Plug. Cranking for up to half hour etc. Had all the same problems until I walloped the relay box and the car magically kicked in. Replaced the relay. Ran fine ever since. Quote Link to comment Share on other sites More sharing options...
dacca Posted July 28, 2017 Author Report Share Posted July 28, 2017 I have changed 109 but was euro car parts one I might try vw one instead but thanks for your time Quote Link to comment Share on other sites More sharing options...
Rich Posted July 28, 2017 Report Share Posted July 28, 2017 wipers off. scuttle off. peel back the left half of the ecu loom and look for corrosion. Quote Link to comment Share on other sites More sharing options...
dacca Posted August 12, 2017 Author Report Share Posted August 12, 2017 UPDATE Time changed 109 relay ,ecu all OK but still no glow plug light, so anymore ideas? Quote Link to comment Share on other sites More sharing options...
Rich Posted August 12, 2017 Report Share Posted August 12, 2017 do as i have already said. Quote Link to comment Share on other sites More sharing options...
dacca Posted August 12, 2017 Author Report Share Posted August 12, 2017 Have done and all ok Quote Link to comment Share on other sites More sharing options...
dacca Posted August 14, 2017 Author Report Share Posted August 14, 2017 Have managed to get a code come up on Delphi and it is 01176 - Key faulty signal to low Does this mean chip in key, key reader on barrel both new key etc etc any ideas? And would this be a reason why no glow plug light and not starting but turning over? Quote Link to comment Share on other sites More sharing options...
Rich Posted August 14, 2017 Report Share Posted August 14, 2017 location? Quote Link to comment Share on other sites More sharing options...
dacca Posted August 14, 2017 Author Report Share Posted August 14, 2017 Where code was found? Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted August 14, 2017 Report Share Posted August 14, 2017 Could be a reader coil fault, part of the barrel. Quote Link to comment Share on other sites More sharing options...
dacca Posted August 14, 2017 Author Report Share Posted August 14, 2017 That's what I was thinking as both keys don't seem to work Quote Link to comment Share on other sites More sharing options...
Rich Posted August 14, 2017 Report Share Posted August 14, 2017 clips off the barrel, plugs into the box near the light switch at the back somewhere. location refers to where you are, if you're local for example i will come fix it. Quote Link to comment Share on other sites More sharing options...
dacca Posted August 14, 2017 Author Report Share Posted August 14, 2017 Also any ideas on where to get one and what I need to do when fitted ie does it need programming? Quote Link to comment Share on other sites More sharing options...
Rich Posted August 14, 2017 Report Share Posted August 14, 2017 no programming, fifteen posted will see one your way, Thursday delivery. Quote Link to comment Share on other sites More sharing options...
dacca Posted August 14, 2017 Author Report Share Posted August 14, 2017 Just now, Rich said: clips off the barrel, plugs into the box near the light switch at the back somewhere. location refers to where you are, if you're local for example i will come fix it. Most of dash is out already due to looking at wires to look for break in cables etc I'm located hertford /ware Quote Link to comment Share on other sites More sharing options...
Rich Posted August 14, 2017 Report Share Posted August 14, 2017 that's miles away! send me your number and we can sort via WhatsApp. 1 Quote Link to comment Share on other sites More sharing options...
dacca Posted August 14, 2017 Author Report Share Posted August 14, 2017 7 minutes ago, Rich said: that's miles away! send me your number and we can sort via WhatsApp. Pm sent ? Quote Link to comment Share on other sites More sharing options...
Rich Posted August 14, 2017 Report Share Posted August 14, 2017 challenge accepted. 1 Quote Link to comment Share on other sites More sharing options...
dacca Posted August 24, 2017 Author Report Share Posted August 24, 2017 Still not working ¡!!!!¡ Quote Link to comment Share on other sites More sharing options...
Pete Posted August 25, 2017 Report Share Posted August 25, 2017 Come on rich, sort it out! Quote Link to comment Share on other sites More sharing options...
