TDI Pedal Box
pjwpjw
that's just a 13mm at the bottom.
the shear bolts above are the nightmare ones.
saying that, start to finish i could have it out in thirty.
Yeah its already bolted in (cut the front brackets off inside the tunnel and utilised the mk2 gti method), selector cables seem a little long but im happy where they sit. Thanks for the info though, appreciate it. Will bear it in mind, I need the pedal box in and then the engine and box is getting installed.
Wehey - replied to your thread. if you can get it out i might be interested dependent on price etc
Edited by pjwpjw
