DannyHorobin Posted June 21, 2017 Report Share Posted June 21, 2017 Hi all, Been reading through a few topics on this but cant find a definate answer. My oil light keeps beeping at me when the car is getting to hot, or so it seems. Im not too bothered about this as the car runs perfectly fine. Does anybody know where i can find the speaker for the beeping noise so i can cut the wire to stop it from annoying me. And if anybody knows how i can fix this problem then that would be greatley appreciated. For now i just want to stop the beeping until i have the time and can be bother to attempt to diagnose the problem. Thanks in advance for your help Danny Quote Link to comment Share on other sites More sharing options...
Rich Posted June 22, 2017 Report Share Posted June 22, 2017 if you take the clocks out and desolder it, you have two problems to fix later. you should replace the oil pressure sensor first, cheaper and easier. what engine is in it? Quote Link to comment Share on other sites More sharing options...
DannyHorobin Posted July 24, 2017 Author Report Share Posted July 24, 2017 Just for info, managed to fix this just by changing the oil for a better quality. Its only a 1.0 but thanks anyway Quote Link to comment Share on other sites More sharing options...
Skezza Posted July 24, 2017 Report Share Posted July 24, 2017 Better quality? So you put the wrong oil in before then? Quote Link to comment Share on other sites More sharing options...
Rich Posted July 25, 2017 Report Share Posted July 25, 2017 maybe by better quality he means thicker? maybe even gearbox oil ? Quote Link to comment Share on other sites More sharing options...
Skezza Posted July 26, 2017 Report Share Posted July 26, 2017 Or too much oil? Or too little oil? Or too thin oil? Or too thick? The fact it's fine now makes me sceptical. Quote Link to comment Share on other sites More sharing options...
