Followers 0
LexG
Radiator fan fuse 20a?
11 posts in this topic
Hi
Ive heard a lot of differering options on what value should be in the fuse box on the right side of the engine ..
some say 20a
some say 30A
some say 40a
my gti has 20a and keeps blowing when the fan kicks in. The fan moves and works.
just had a new radiator fitted too.
Is the 20a fuse wrong?
cheers
according to my list F48 = 25a F49= 25a
unless you have the specific number but these relate to the blower motor
It's the fuse in the fuse box in the engine bay for the radiator fan
He said it was on the right next to the engine, not the cabin fuse box.
I'll go have a look in a min. Seems more like a short than anything else though, a lower amp rated fuse would give in after a bit but it's unusual for it to spit its dummy out as soon as the component kicks in. Not at those amp ratings anyway.
Ok damn.. I thought it might just be the wrong fuse !! I need the car tomorrow as well!!
Red is 10, yellow 20, green 30.
Thanks ..that's exactly what I have .. something else is up then
possible knackered fan then or the wiring got damaged/pinched when the radiator was refitted, assuming it was all working ok beforehand
The front fan on my old GTI stopped working and we replaced it, the replacement was an OEM part and would blow the 20a fuse every time it kicked in so I just put a 30a in and it worked like clockwork until the car was killed. Maybe not the correct solution but meh!
Followers 0
