Gingerninja
Will these seats fit in my arosa?
Rears no.
Fronts. Possibly. You have to check what runners you have. Some arosa's have different seat runners. I have seen these in couple. The easiest way is to check is pull the front seat all the way back and check what connector you have at the front. If you have a rectangle with two holes then no. If you have the other type then yes.
I found a picture of the other type of seat base connector in this thread. I hope this helps.
I think MK1 Arosa's have the same seat mounts as 6N Polo, Mk3 Golf and mk2 Ibiza, so if those seats are from any of those cars, they should fit.
