vlavhs
lupo 1.4s convert to ajv(do need your help again!!!)
hello i had made another topic some time ago.I need your appreciated help again!!!
after much search around Greece for 1.6 engine no avy or arc around at all.
i found an ajv one from a polo with 180.000 kilometers.There is no gearbox so i need to know if i can use mine.
As much i have read its an engine with 120 hp power and drive by cable(mine is also dbc).I can also buy with this the ecu,the driveshafts with the brakes and the clocks.
there is no loom(i have found one on ebay for 200 euros!!!).
so the questions are these;
1)can i use my gearbox?
2)i need only the engine loom right?if so any possibility used from another model?or only from ajv?
3)the driveshafts will fit in lupo?both front and back?
4)my car doesnt have abs will i be able to use?
5)are the engine mounts the same as are with avy?
6)as long as i have the ajv exhaust manifold will i be able for start to use the rest of the exhaust?
7)any other loom i can use?
the engine,ecu,driveshafts and clocks will cost me somewhere around 500 euros
is there anything else i will need and i forget i do?i need to have a budget on my mind to decide whats better.
a 1.6 8v?
why don't you find an afh?
16 minutes ago, Rich said:
a 1.6 8v?
its 16v as much as i know :huh: its the engine from polo 6n http://www.ebay.com/itm/1-6-16V-VW-GTI-AJV-Motor-UMBAUPAKET-UMBAUKIT-Polo-6N-/180692322790?hash=item2a121a09e6:m:mOw8FrbGJcsqP78mlftCF_w&vxp=mtr
like that is the engine and also afh as much i read from your site is only good to make an hybrid by using its head with 1.6 bottom.afh isnt also 101 hp?
rare 6n gti engine, buy it.
your box will go on (but not for long)
easy to make work.
easy to make work.
if you have time give a look to other questions also.can i make something to my own box to get it stronger?i would prefer to keep mine in order to have faster changes
just don't really hammer it.
drivetrain will fit.
wiring, anything is possible. ......
