Centre Bore on alloys too small
Spucky
It'd take a machine shop five minutes a wheel. And it'd be accurate too. I'm sure that there's someone local to you with a decent size lathe. They'll simply need to know the exact size of the hole needed. I'd imagine a fiver a wheel would cover it. Just make a few phone calls or speak to your nearest farmer in s wales. They know all the right people!
  • Like 2
11 hours ago, Spucky said:
Found a local place to do it cheap with a big lathe. Cheers for the suggestions
Lots of before and after pics please :)
Thinking about the opposite of the problem, the center bore being too big, and I can only think if only someone would have invented a device that you could put in to reduce the size..
Nope.
That would never take off. Just buy wheels that fit. :rolleyes:
A flap wheel on a drill will sort it
No need for expensive machining.
I opened up the crank cases on my old C90 with such a method.
Works a treat ??
#ghetto engineering
Edited by wehey
Here's the the before and afterIMG_20170518_132709.thumb.jpg.bf8cb786a5af88a0d4620a67a9d16e07.jpg
They need a good clean and the centre caps don't sit right because the wheel nuts are too big.
Also I apologise for the sticker. It's of bad taste I know.
Edited by Spucky
Nope.
Erm... Spigot rings?
:rolleyes::rolleyes:
Yes. Perhaps the sarcasm didn't come across all that well here. But it was in reference to
" buying wheels that fit is doing it properly." - My point is that plenty of people buy wheels that don't fit, but can be made to fit either through Spigot Rings or machining the center.
