Rallyedude
Lupo 1.8T mounting style questions
Right , so just bought a 2001 Lupo 1.8t yesterday. Now , here in Canada this is a big deal. Lupos are not legal here unless older than 15yrs. So an importer I know kind of surprised me this week with a phone call telling me his container was coming in last tuesday. So, how could I say no... I remember seeing Venom's green one at Inter's years ago. A Lupo has been on my list ever since.
 I've been reading about motor swap ideas since I got the call earlier this week. I'd love a VR 24V but, any install I've seen involves a lot of chopping of body. So, 1.8T it is. I like the idea of Mk3 style welded on to stock subframe , Then custom front mount .  Anyone have a better idea? Or is there a mount install kit available?
 I've built 4 Mk1 VR's before with 3 different mounting systems, I've built 2 syncro corrado's , TDi swaps, B3/before passat syncro swaps, 1.8T swaps, 2.7T audi 90, etc. So the 1.8T Lupo is certainly do-able. But evidently the UK has 15 yrs of knowledge on me in this area .  So, ideas ? thanks, Rune.
Edited by Rallyedude
a. Read a few threads.
generally the leg mounts are the most used mounting method.
polo 9n3 inlet allows more manipulation with mounting.
if it is an rhd lupo, use a tdi or gti pedalbox for the hydro clutch.
gti or tdi selector for cables.
I did see that red one . I see he used a lower brace . Sort of a variant on mk4 pendulum style mount .  Of that style , the most solid mount seems to be when the use mk4 lower dogbone. But you end up with less road clearance.
I'm leaning towards mk3 mounts . Keeps your chassis legs clear . I only found this one in Sweden . http://www.mestmotor.se/bilsnack/forum/showthread.php?359111-vr6nitrous-Henkes-Lupo-1-8t-projekt&s=fd8035b26ca15337878e46b4543fe3c9
Although it looks like a left side bracket from an Audi A4 longitudinal set up used as ft mount .  I'd probably just rock a mk3 4cyl 02A bracket . Build up a from subframe to meet up to it .
The AEB is the longitudinal equivalent to the AGU that some like for the big ports, so it the engine mount makes sense in this case.
Yes I'm aware of port size differences . Honestly with a k03s 180hp motor (with programming @215hp) I'll be happy enough . From 49 to 215hp . I'm happy with that !  Trying to get it through safety check right now . Quebec doesn't like coilovers . My German contact should be bringing a stock suspension in a week or so . My mk6 Rwagon project is next on my list . The Lupo swap will be this winter !
I blame the want of this project on venom's vomit green Lupo 1.8t from back in the day . Saw it at inters knew I had to have one !
I'm with you. 1000bhp+ has been done on the small port heads anyway. The AGU/AEB isn't all that. Plus DBW has its tuning benefits.
I've got a spare AJQ(180/240) dyno'd at 231PS/332Nm and minimal lag on a K03 and ME7. I'm tempted to put it in a Lupo and be done.
so which US rallye are you then?
if you're the chop/rebuild guy then you are somewhat legendary
I'm in Canada . I think you're talking about the red one that got rebuilt on a USA spec Montana green shell . That one is amazing .
I just used to fund my uk trips bringing euro spec parts back  to Canada in the 90's.
I bought mine from Jim at awesome years ago . Then got married, side tracked . But back on track these days !
This is my most recent build . Smyth kit I call "divorce therapy".Take a mk4 4dr, cut half off , install kit . Now I got a BDF Ute !
I spent some time with the stupid ute that was created over here.
my only gripe with that car was the lack of cabin foot space.
The silver one based on  a wagon? Loved the look of that car . Mine has reduced leg room . I'm 6'2", it's a bit tight . Reality it's kind of useless for my lifestyle . If it had a locking tonneau cover itd be perfect.  But I'm selling it so won't be my problem!
the silver one which became blue. (wrapped)
there's no way to do it nicely whilst still getting a decent bed from it.
Got my 2.5 stainless exhaust built ! Getting ready for 1.8T!
most do that last. :)
makes sense this way.
Yes but I want the worlds lowest torque 1.0L!!!!
plus stock replacement 1.0L exhausts aren't exactly available over here .
I did some reading on control arm bushings . Thought they were same as mk4 golf . Took it apart . Apparently not !
Any recommendations on upgrades ? Is there a factory solid version? I'd rather not go poly .
if the Tt ones don't fit then there isn't going to be a solid option.
are you sure they're a different size?
Really ? Maybe my micrometer eye is off . I pulled control arm off but didn't push out bushing . It sure seemed smaller . I'll call vw
i bought a couple for a lupo from Ecp, ended up using them in a golf mk4.
What do people typically use  to convert to 5 lug and rear disc brakes ?
 The ft looks like some mk3 VR parts could be made to work with not huge hassle . My 1.0L has drums .  Seems like most people switch rear beams to a gti model to get mounting tabs for rear caliper . I'm thinking my best bet might be to use mk3 disc rear stub axles ( which incorporate caliper mounting tabs). Any other suggestions? That don't involve shipping a gti beam across the Atlantic.
the mounts on the gti are a separate plate.
asides from that, you can just use the mk3 set up, bolts straight on.
why not just save some time/money and import a proper gti and just keep it 100% stock?
maybe not money....
Actually I'm getting someone to look at a gti next week . And I'd run it stock . But gti's keep value so playing around with this 1.0L doesn't bother me  .  Also having more easily available parts on it makes future maintenance easier . Instead of waiting two months to get parts , two hours .
Thanks for the help !
