mickyfinn
seat arosa non start
thanx guys will do more checks tomorrow,another day another dollar will post results for future reference thanx again
hi guys back again with car still cutting out ,had plug in with vagcom or vcds came up with ecuimmobiliser lock out,cleared fault drove gain ok for few miles,cuts out wont start,leave for 10 mins will restart and drive abit more,cuts out again,any help wood be appreciated,thanx again
What code was it? It helps because you can look it up and narrow it down some more...
If you have 2 keys try the other one for starters.
Otherwise temp sensor is a good candidate if your temp gauge is reading off.
Edited by Sausage
hi guys back again,replaced the temp sensor and car still cuts out,seems better it only takes couple minutes to restart but still cuts out,any help,info,advice greatfully received as loosing faith in once a great little car thanx again......
afternoon people,still having fun with little seat arosa cutting out,most electrical parts replaced,still cuts out and will restart but is a pain.checked all plug connections for corrosion/moisture all look ok,did read that they loose feed from ignition to coil?any body shed any light,thoughts please help need my car thanx in advance
If the spark plugs have no spark and injectors do not receive fuel when it does not start then check/replace the Hall sender (G40)
http://workshop-manuals.com/volkswagen/golf-mk3/power_unit/motronic_injection_and_ignition_system/ignition_system_glow_plug_system/servicing_ignition_system/removing_and_installing_parts_of_the_ignition_system/
Fault of immobilizer causes the engine to stop to a one second after starting.
evening folks,the seat runs fine till warms up then cuts out for while to cool down I guess . so far car has had new distributor ,coolant sensor,ignition coil,leads are ok,new plugs,new ignition switch,just cant pinpoint fault or with scan unit . I think it might be ecu fault,has anybody come across this fault or similar . thanx muchly
Get VCDS on it and read the temperatures there, if the ecu is reading very wrong temps from the sensor it will be throwing a wobbly, if the temps look about right then it is elsewhere.
thanx sausage fo help,am back again still cutting out car runs fine till warm then cuts out wont restart,leave for 30 mins car will restart and drive till warm again.have noticed from cold the temp guage reaches operating temp in 3 mins when hoses are only 20 odd degrees,have changed temp sensor could it be guage fault? is this partly why it cuts out,any help wood be great thanx muchly people.
