mickyfinn Posted March 15, 2017 Report Share Posted March 15, 2017 hi all having problems with little arosa 1400 mpi,has had new dizzy,leads,plugs,fuel relay,new coil sometimes it starts then cuts out,when driving cuts out and will not restart,currently been 2 days and wont go.have had computer on it,no faults or codes.any ideas pleeze wood be appreciated,thanx muchly. Quote Link to comment Share on other sites More sharing options...
Sausage Posted March 15, 2017 Report Share Posted March 15, 2017 Using what reader and software? Try it with vcds if it wasnt what you used. Sounds like a cam or crank position sensor, but pointless guessing as vcds would tell you. Quote Link to comment Share on other sites More sharing options...
Mobieus_uk Posted March 15, 2017 Report Share Posted March 15, 2017 (edited) after my cambelt woes im pretty sure the cam position sensor will throw 1 of 2 codes, implausable signal which is definetly timing is out, and no signal meaning the sensor is toast or had become diconnected, maybe a few more but a code would be shown, I'm thinking more of fuel pump in the tank, im sure a member here had a similar problem and when the fuel pump in the tank was replaced all was well Edited March 15, 2017 by Mobieus_uk Quote Link to comment Share on other sites More sharing options...
mickyfinn Posted March 15, 2017 Author Report Share Posted March 15, 2017 (edited) was using obd reader,it does not have cam sensor I think as its got distributor,will faulty crank sensor cause the car to run for a bit then cut out,finally not starting at all.....if crank sensor where is it thanx again..... Ā Edited March 15, 2017 by mickyfinn Quote Link to comment Share on other sites More sharing options...
Sausage Posted March 15, 2017 Report Share Posted March 15, 2017 Did it have these problems before new dizzy, leads, plugs or only after? Quote Link to comment Share on other sites More sharing options...
mickyfinn Posted March 15, 2017 Author Report Share Posted March 15, 2017 did have cutting out problem before new parts went on,had to fit new parts as old ones 1997 was worn out and thought that wood cure it,do you think could be crank sensor but did not get any warning lights or fault codes Ā Quote Link to comment Share on other sites More sharing options...
Sausage Posted March 15, 2017 Report Share Posted March 15, 2017 What software did you use on the obd lead? Quote Link to comment Share on other sites More sharing options...
mickyfinn Posted March 15, 2017 Author Report Share Posted March 15, 2017 (edited) Ā not sure what software used,its a handheld obd reader,what wood you recommend to diagnose further by any chance do you know where the crank sensor is located,so I can pull it and test Ā Edited March 15, 2017 by mickyfinn Quote Link to comment Share on other sites More sharing options...
Sausage Posted March 15, 2017 Report Share Posted March 15, 2017 (edited) Get a cheap kkl lead of ebay preferably with a genuine ftdi chip in it (Ā£5 - Ā£10) and run vcds lite free or registered version (paid for or cracked) on a spare laptop. Seen it before where other readers dont pick up fault codes that vcds does. http://www.ross-tech.com/vcds-lite/ Edited March 15, 2017 by Sausage Quote Link to comment Share on other sites More sharing options...
mickyfinn Posted March 15, 2017 Author Report Share Posted March 15, 2017 thanx for your help,will give it a go,will report back with faults lol Quote Link to comment Share on other sites More sharing options...
Rich Posted March 15, 2017 Report Share Posted March 15, 2017 this is very liable to be crank sensor. located under the starter motor in the bell housing Quote Link to comment Share on other sites More sharing options...
mickyfinn Posted March 15, 2017 Author Report Share Posted March 15, 2017 thanx rich will give a go,they not expensive,and got nothing too loose Quote Link to comment Share on other sites More sharing options...
mickyfinn Posted March 16, 2017 Author Report Share Posted March 16, 2017 help......after a mother of a battle managed to remove starter motor and nothing there,no wiring or sensor.all I could see was knock sensor.any ideas where it could be located maybe under cam cover somewhere. I am lost with this one,any help wood be appreciated.car seat arosa 1400 mpi 1998 thanx guys Quote Link to comment Share on other sites More sharing options...
Rich Posted March 16, 2017 Report Share Posted March 16, 2017 aaah, apx engine? Quote Link to comment Share on other sites More sharing options...
mickyfinn Posted March 16, 2017 Author Report Share Posted March 16, 2017 engine code aex on cam cover Quote Link to comment Share on other sites More sharing options...
mickyfinn Posted March 18, 2017 Author Report Share Posted March 18, 2017 hi guys am still fighting non runnerĀ have removed starter motor cant find sensor,nothing in timing cover running out time and patience,can any body help please Quote Link to comment Share on other sites More sharing options...
Rich Posted March 18, 2017 Report Share Posted March 18, 2017 I don't think it has a crank sensor. you might be best googling polo mk4 as they shared the same engine. it may bring something up the same Quote Link to comment Share on other sites More sharing options...
mickyfinn Posted March 18, 2017 Author Report Share Posted March 18, 2017 today have done more checks and have no spark,am thinking immobiliser fault as seen on other pages have admitted defeat and gonna find auto electrician just cant be bothered thanx for all your help Quote Link to comment Share on other sites More sharing options...
Rich Posted March 18, 2017 Report Share Posted March 18, 2017 relay problem? immob would start and cut out Quote Link to comment Share on other sites More sharing options...
Sausage Posted March 19, 2017 Report Share Posted March 19, 2017 Let us know what it was when you find out please. Deffo sounds electrical. http://www.aa1car.com/library/no_spark.htm Quote Link to comment Share on other sites More sharing options...
mickyfinn Posted March 21, 2017 Author Report Share Posted March 21, 2017 (edited) back again....lol ...after testing guy said poss ecu gone down,,anybody heard this before or is he trying to fleece me lots of money most of parts on car dated 1997,is it worth paying to be tested or replaced,thanx guys he did mention the immobiliser was part of dash,is this right??? do the dash go wrong....help!!!!!!!!!! Edited March 21, 2017 by mickyfinn Quote Link to comment Share on other sites More sharing options...
Sausage Posted March 21, 2017 Report Share Posted March 21, 2017 If code reader consistently has comms with ecu then I'd say no. VCDS would make that obvious btw while connecting to ecu. Immo isnt part of dash until immo 3 cars afaik. Quote Link to comment Share on other sites More sharing options...
mickyfinn Posted March 21, 2017 Author Report Share Posted March 21, 2017 thanx sausage have wondered did the arosa have relay 109 as could not find it on board or is it separate from board the car is 1998 1400 mpi,just have no spark,good little car up till now Quote Link to comment Share on other sites More sharing options...
Rich Posted March 21, 2017 Report Share Posted March 21, 2017 look up mk4 polos, one must have had the same issue. 1 Quote Link to comment Share on other sites More sharing options...
Sausage Posted March 21, 2017 Report Share Posted March 21, 2017 http://www.seatcupra.net/forums/showthread.php?t=204001 ecu connections was his problem, unplug the big plugs do a visual inspection for green corrosionĀ and plug unplug them a few times to clean the connections, but a few other things to check on the way too. 1 Quote Link to comment Share on other sites More sharing options...
