thierryrichards Posted January 19, 2017 Report Share Posted January 19, 2017 Hi all. Posted on here about intermittent non start and now complete non start. Anyway, today I committed cardinal sin of easy start just to see if it was firing. It would start then cut out which made me think fuel. So I took what I think is fuel line into injectors and off and cranked and nothing. Could you guys confirm if this is fuel in? And the fact no fuel comes out when I crank would be an indicator of the problem? It's a 1.0 mpi Quote Link to comment Share on other sites More sharing options...
Sausage Posted January 19, 2017 Report Share Posted January 19, 2017 We needs the fault codes.... Quote Link to comment Share on other sites More sharing options...
Joechapl Posted January 19, 2017 Report Share Posted January 19, 2017 Fault codes may be a help. If nothing, lift up the back seats and unscrew the black cover, there reveals your fuel pump. Turn the ignition on after doing so and listen for a whir. If nothing happens, check your fuse #40 if that's not blown. If it isn't, check your relay #409 I think. Are you sure its not the cam sensor and not removing the wrong pipe? Quote Link to comment Share on other sites More sharing options...
thierryrichards Posted January 19, 2017 Author Report Share Posted January 19, 2017 Fault codes are longstanding ones pne is EGR and the other is a misfire on each cylinder. I would have to plug in at weekend to get them again Quote Link to comment Share on other sites More sharing options...
Sausage Posted January 19, 2017 Report Share Posted January 19, 2017 (edited) Do a compression test to satisfy yourself that it isnt mechanical before spending money on bits. Testers for petrols are sub £20 so no point paying someone to do it and then you have it for years. But it does just sound like a sensor or no fuel getting thru. Pull the plugs and if they are wet then fuel is getting thru, they should all be similar colour and condition (look up plug charts), if not note which cylinder the odd one came out of. Edited January 19, 2017 by Sausage Quote Link to comment Share on other sites More sharing options...
thierryrichards Posted January 20, 2017 Author Report Share Posted January 20, 2017 Thanks for reply, plugs were bone dry with slight signs of white powder on them but not loads. WIll see if I can borrow a tester. Will also check for fuel pump noise, i havnt tried the cam sensor. THe pipe into the Injector rail had arrow on going into the rail so it must be the correct one I would think. I just didnt know whether if disconnected it would still pull through or not Quote Link to comment Share on other sites More sharing options...
cj1 Posted January 20, 2017 Report Share Posted January 20, 2017 It looks like the fuel line is still connected on that picture. Quote Link to comment Share on other sites More sharing options...
thierryrichards Posted January 20, 2017 Author Report Share Posted January 20, 2017 Hi cj1 This is where I wasnt entirely sure. The pipe where the tip of my screwdriver one is the one that I have removed Quote Link to comment Share on other sites More sharing options...
