Crunchy brakes?
So I've noticed every now and again my brakes are going crunchy. Best way I can describe it. Like exactly how when it's icy and you brake and it does that crunchy feeling.
Does anyone know what I can do to fix it? Because it's pretty scary. Especially when I brake and it just crunches.
Im driving so so slow now because I darent do more than 30 lol.
The abs light comes off and on, I think I mentioned this in an earlier post. But yes like you can feel it in your foot too.
How much will a scan cost roughly?
Omg .. Rich please help me to fix it for free haha
It just cut out?!
Sounds like you have the upmarket abs system. I have friction pads, some fluid and pipes. That's it in poverty spec SDI... Worst case I chuck the anchor out the window.
5 hours ago, Rich said:
describe what it did.
Ok so I was slowing down coming to a junction, doing about 15mph, then the brakes went hard and the steering went off. I didnt know what had happened and then noticed the battery light like as if when you stall it, so i turned it off and on again, big cloud of white smoke out the back then it did it again about 2-3 minutes later... I like the idea you had before, I think that would be the best option, but I need it to be red lol.
1 hour ago, mk2 said:
It just cut out?!
I wish I had an anchor :/
It's a good job I wasn't going fast round a corner I would have seriously died. I NEED power steering, My arms aren't strong. ha
1 hour ago, Pete said:
And I doubt the abs/brakes issue has anything to do with the engine cutting out.
Yeah I didn't think they were related, could it maybe be the battery or a spark plug or something? (Yes, I am unaware of what a spark plug is for, it's just fun to say)
Has anyone figured out why her car uses so much oil? Have I missed a post on the subject...?
The VW Queen Rich said it could be the rings, I am taking him up on the whole, 'Sell it.' idea.
I am so sad.
This is a sad day.
I may make a JustGiving page to help my lupo live.
I once came across a very unusual situation where a leaky brake servo leaked brake fluid down the vacuum pipe... Brakes behaved weird, smoke and engine cut out! But from what I've been reading, I think it's more likely to be engine oil.
20 minutes ago, mk2 said:
If its the rings, I wonder how much the engine blows back. If the crankcase breather were disconnected, it might reduce the oil burning...?
Now you are speaking greek to me :/ haha there's a lot of smoke if thats what you mean?
Ive used 15/40 is that the right oil to use?
Do you know if the car had been left unused for a long time? If yes, then it may be nothing more than stuck rings... Add 1:50 diesel to your petrol. And remove each spark plug and add about a tablespoon or two of diesel to each cylinder and allow to soak for at least 48h. Might cure it. Old trick!
10 minutes ago, Pete said:
so did the steering go and the brakes when the engine died?
Yeah it went all stiff. Danno has just done a scan thingy and it said something about the front drivers side ABS sensor? Could that be the cause? Or is that something different entirely?
