OsLupo
Remote Central Locking
Hello everyone I currently own a lupo 1.4s. I recently bought a remote central locking system howvever it is not the Rclick one it is called paolo.
Im having some trouble wiring it in was wondering wether anyone could help as far as I know the red goes to the yellow and blue wire in the brown plug then the 3 grounds to a Bolt however now I'm stuck not knowing where the wires go as the diagram is crap.
would really appreciate the help
a picture below showing the wire colours :)
Edited by OsLupo
You need a better wiring diagram or a multimeter.
That is THE worst schematic diagram I have ever seen! And I draw some of mine on my hand! What the hell is that grey box supposed to be?
contact the makers and tell them the car you are fitting it on, they should then provide you some information that tells you which wires you need to connect to in the car
or return it and buy a hawk central locking kit, tell them the car and they provide a wiring diagram that relates to your car
Edited by Mobieus_uk
I know the diagrams crap haha , I think I'm gunna send this one back and get the Rclick now I have found out about it
You don't need an expensive r click but the wiring diagram needs to tell you which wire does what and that diagram simply doesn't. Telling you that six wires are 'central locking' is useless.
You need unlock, lock, which is ground etc.
Anyway, hope they can supply a better diagram. That one is just silly.
You could always blast the multimeter out but you will be in the dark a bit
Yea get the multimeter out, have it sussed in no time!
Assuming it's set up for positive pulse central locking. If it's set up for negative pulse then it'll be harder potentially
hi guys just thought id let you know i finally managed to figure out the wiring ! i belive it was a negative pulse but hey ho all works now
Did you get it working in the lupo
