weslangdon Posted October 21, 2016 Report Share Posted October 21, 2016 when the drivers side of my Lupo Auto is parked pointing in a slight downward direction it leaks into the drivers footwell and the rear passengers footwell after rain, I've tried putting a wire down the right side drain hole for the sunroof with no success, any ideas Quote Link to comment Share on other sites More sharing options...
mk2 Posted October 21, 2016 Report Share Posted October 21, 2016 R u sure its not the door? Mine used to leak in the same way, and I have no sunroof.... Quote Link to comment Share on other sites More sharing options...
weslangdon Posted October 22, 2016 Author Report Share Posted October 22, 2016 I think that it would leak all of the time when it rains if it were the door, but it only happens when the sun roof should be draining into the right front corner. This makes me thing the drain is blocked but so far I cant find where the outlet should be. The fact of it being lowered doesn't help Quote Link to comment Share on other sites More sharing options...
Silver! Posted October 23, 2016 Report Share Posted October 23, 2016 Can you not push a piece of stiff wire down from the top? Quote Link to comment Share on other sites More sharing options...
weslangdon Posted October 23, 2016 Author Report Share Posted October 23, 2016 I've tried a bit of electrical wire but with no success Quote Link to comment Share on other sites More sharing options...
Loop'd Posted October 23, 2016 Report Share Posted October 23, 2016 check you scuttle drains bottom of the windscreen. Quote Link to comment Share on other sites More sharing options...
weslangdon Posted October 23, 2016 Author Report Share Posted October 23, 2016 I've checked them too, seem ok, I think its the sunroof drain pipe Quote Link to comment Share on other sites More sharing options...
Silver! Posted October 23, 2016 Report Share Posted October 23, 2016 Wire coat hanger? That's what I used to use when I had a sunroof with blocked drainage. Quote Link to comment Share on other sites More sharing options...
