mk1 arosa 1.8 20vt project questions about drive shafts
arosa man dan
hi there I'm doing a 1.820vt conversion on my mk1 arosa and I'm going to use the 5 speed box but am just wondering as I'm aware that you need to shorten the passenger side drive shaft has anyone ever tried running a breadvan drive shaft as I have one laying about and it seams to be a lot shorter
According to that it needs to be approx 40mm shorter depending on how you have mounted the engine. I'm not sure how GTI figures translate to a mk1 arosa though. Just make sure the shaft wont bottom out with suspension travel and engine / gearbox movement, i.e hard cornering etc.
Edited by Sausage
