Splitting gear gaiter and knob
pk1was
Got a new gear knob and gaiter for my GTi but the new one has the later model faux gaiter how do i seperate the gaiter so i can swap them over?
I did this the other day... You need to force the plastic sleeve that clamps the gaiter to the knob apart. It has a serrated edge where you need to push in a flat blade screwdriver to slide the sleeveĀ  down the shaft away from the knob. Then everything becomes obvious.
