Sausage Posted August 9, 2016 Report Share Posted August 9, 2016 After some specs for the front hubs and bearings. Pics if you have them too. Correct me if i am wrong, from what i have seen today front bearing inner diameter should be 35mm as the lupo front hub outer diameter is 35mm? Front bearing outer diameter and depth? Front hub drive shaft spline count and diameter? Front hub depth? etc etc. If you know what audi hubs, shafts, bearings brakes etc will go on with some persuasion to give 108 pcd then let me know. Cheers Quote Link to comment Share on other sites More sharing options...
Sausage Posted August 22, 2016 Author Report Share Posted August 22, 2016 (edited) Bought this Polo TDI one for messing about with: It looked the same as Lupo TDI, but anyone confirm it actually is? It has a very new smooth bearing in it, it will be a shame to break it and then find out it is different part. Edited August 22, 2016 by Sausage Quote Link to comment Share on other sites More sharing options...
