Jackyl Posted July 28, 2016 Report Share Posted July 28, 2016 Hello. huge problem for me... today after fitting the new front suspension (by me), somehow the wiring harness has been "cutted", right next to the "fire wall". i have the wire on my hand, and the rest is inside the fire wall. i can feel it, but cant pull it out. how do i reach the cable to solder? in the engine bay i cant find the cable (must be inside some wall)... now the esp and abs are always on. damn it... in my case is the passenger side (on yours is the driving side) help... thank you. Quote Link to comment Share on other sites More sharing options...
Pete Posted July 29, 2016 Report Share Posted July 29, 2016 It will definitely be in the engine bay somewhere. Best idea is to disconnect the plug for the sensor at the hub end, find the cut wires in the bay, carry out the repair in the bay and post the sensor back through where the brake lines run through. Quote Link to comment Share on other sites More sharing options...
Jackyl Posted July 29, 2016 Author Report Share Posted July 29, 2016 Hello. Thanks for the reply. I did what you said. put a light on the wheel arch to see in the engine bay where the light came out. and found the wire. so weird. The cable on the engine side, perfectly cut. the cable on the wheel side (sensor) had the wires like it was previously connect to something. (dont know the english word for it (ready to put some terminals). resuming: Found the cables, attached some terminals and a little bit of wire. connected to the sensor. VAG-COM, erased the errors. All done. Thanks Quote Link to comment Share on other sites More sharing options...
