Egr problems
Dannyteee
Hi all, EGR valve went again so took it off to clean, when it came to putting it back in I decided I wanted to drop the bolts down into the engine bay along with a few Allen keys, managed to get my tools back but can't get the one bolt which has louged it's self near the gearbox, was wondering if any one knew the specs so I can go get another one
cheers
Well the EGR is back, the car is still running bad so ran a check through the laptop, got 5 fault codes ? Would any one happen to know a solution to this one because I have no idea, "manifold / barometric pressure sensor (g71) / (f96)" this a also led to the car misfiring as well
any help would be appreciated
Hi
Can you not just block it?  My Sdi was running appallingly, read up on blocking, did and now the car runs great, I swear it even stopped a slow puncture on the right rear too (that last bit might not be true :) )
cheers
Ian
Ah, you've spotted the flaw in my thinking, I have no idea, correction, I know what one is, just don't know what that one does, probably something to do with actuating the EGR valve but if it's showing it shut (or rather no through flow) I don't see, other than reporting a fault, it makes a great deal of difference.
Cheers
Ian
  • 3 weeks later...
  • 3 weeks later...
