Romany12 Posted May 6, 2016 Report Share Posted May 6, 2016 It's a 2004 Arosa S - great little car, but a locking problem. I first noticed when using the remote fob that sometimes it would lock/unlock, then sometimes not. New battery in the fob, of course, but no difference. I then started using the key instead of the fob which was fine for a while, but although it always opens, most if the time it will only lock the driver door, not the boot or passenger door. Summer's coming and I need to leave stuff in the car overnight - where should I start looking? Any advice gratefully accepted. Quote Link to comment Share on other sites More sharing options...
pond Posted May 8, 2016 Report Share Posted May 8, 2016 I haven't got an answer that is specific to Arosa but sometimes a small amount of corrosion on any of the C/L circuit connectors can cause that kind of fault generally. My first Arosa would randomly lock itself despite no key in ignition/doors shut so had to always remember to never leave the keys on the seat/in the boot area temporarily as only had one key. Quote Link to comment Share on other sites More sharing options...
Romany12 Posted May 8, 2016 Author Report Share Posted May 8, 2016 Thanks for that. Are the central locking connectors distributed around the car at each door, or is there a central point? I've never managed to discover where the receiver for the remote fob signal is located - might that be the central connection point for the central locking? If you know what I mean. Quote Link to comment Share on other sites More sharing options...
Romany12 Posted May 9, 2016 Author Report Share Posted May 9, 2016 Well, the connector plug underneath the driver's armrest central lock/unlock switches was hanging down a bit - took it out, cleaned it and pushed it back in - lo and behold normal service has been resumed. Thanks Pond for pointing me at connectors - I was thinking perhaps one of the cables in the loom where it bends to pass into the door might have fractured and being horrified about how I would (or probably would not) find it! Quote Link to comment Share on other sites More sharing options...
Skezza Posted May 11, 2016 Report Share Posted May 11, 2016 The mechanisms are old and need either restoring or replacing. Not a huge job, but they're not expensive to replace so... Quote Link to comment Share on other sites More sharing options...
