camzere Posted May 6, 2016 Report Share Posted May 6, 2016 Hi, I'm new to the forum so not sure if I will get a reply. I bought a 2002 Arosa on Monday and since then, I have noticed a few problems with it. Mostly with lighting! The hazards weren't working but I changed the fuse for them and they now work. However, I can't get the Interior light or the light behind the heaters to work. I tried a different fuse for the interior light but that didn't do anything. I also tried 3 different bulbs from friends and they didn't work either. (the bulbs work in their cars). Also, i think the light does work for the heater dials because when I click the re-circulation button, that lights up? I can't think of anything else to try! Any help with be greatly appreciated! Thanks Quote Link to comment Share on other sites More sharing options...
mattarosa Posted May 6, 2016 Report Share Posted May 6, 2016 Pull the speed control knob out, it may be stiff, carefully remove the lamp, I use heatproof sleeping from downlights and a pair of snipe nose pliers but not everyone has the things I've listed, most use electrical tape rolled into a tube and snipe/needle nose pliers, it's a different lamp to the recirculating one. As for the interior light, do you know it rocks from side so side for you? Do you have a multimeter? If so just set it to voltage and bob it across the terminals and see if you get anything. If not trace it back. It could be a second dodgy fuse. Quote Link to comment Share on other sites More sharing options...
camzere Posted May 9, 2016 Author Report Share Posted May 9, 2016 Hi Matt., I will give this a go when I get home later. Thank you! Quote Link to comment Share on other sites More sharing options...
