Adam-red lupo Posted February 26, 2016 Report Share Posted February 26, 2016 I want to install a pioneer car stereo but I can't find the correct cables for it can anyone help me and tell me the specific cables I need it's a pioneer DEH-X3500UI and I can't put it in my car because I don't have the cables can anyone help and tell me what I need? Thanks- Adam Quote Link to comment Share on other sites More sharing options...
myles983 Posted February 26, 2016 Report Share Posted February 26, 2016 Have a look at this. Myles. Quote Link to comment Share on other sites More sharing options...
stator Posted February 26, 2016 Report Share Posted February 26, 2016 You shouldn't need any connectors, all you need to do is take the ISO harness that comes with the unit and swap the yellow and red bullet connectors around. You might need an aerial connector, the long type you push in Quote Link to comment Share on other sites More sharing options...
Mobieus_uk Posted February 26, 2016 Report Share Posted February 26, 2016 (edited) have you got this bit http://www.ebay.co.uk/itm/PIONEER-DEH-X3500UI-Model-Car-Radio-Stereo-16-Pin-Wiring-Harness-Loom-ISO-Lead-/252074478595?hash=item3ab0cf4c03:g:ZNAAAOSwMmBV4yFm if so the lupo should plug straight in, if not then that is the bit you need, if someone has cut off the oem plugs then still not a worry you still need the radio connector cheaper version http://www.ebay.co.uk/itm/Pioneer-16-Pin-Car-Stereo-Radio-ISO-Wiring-Harness-Adaptor-Cable-Lead-Loom-Wire-/121609748934?hash=item1c508181c6:g:kkMAAOSwPhdVGmMl Edited February 26, 2016 by Mobieus_uk found cheaper version Quote Link to comment Share on other sites More sharing options...
Skezza Posted February 26, 2016 Report Share Posted February 26, 2016 48 minutes ago, stator said: You shouldn't need any connectors, all you need to do is take the ISO harness that comes with the unit and swap the yellow and red bullet connectors around. You might need an aerial connector, the long type you push in That's only if it comes with an OEM harness, some don't. Quote Link to comment Share on other sites More sharing options...
