LupinGTI Posted February 16, 2016 Report Share Posted February 16, 2016 Hi there has anyone experience this: when changing gears, for around a second, the revs remain high or where they were when upon change. So at 3000rpm I´ll change into say 3rd gear and in the time that it takes me to make the change, the trottle remains at this rpm despite the clutch being engaged. Any ideas? Thanks Quote Link to comment Share on other sites More sharing options...
Low N' Slow Posted February 29, 2016 Report Share Posted February 29, 2016 I have the same issue, I've wondered whether it's just a sensor or something, but it is a bit annoying so I'd like to find out too!! Quote Link to comment Share on other sites More sharing options...
Ropers101 Posted March 4, 2016 Report Share Posted March 4, 2016 I'm also interested in this Quote Link to comment Share on other sites More sharing options...
Sausage Posted March 4, 2016 Report Share Posted March 4, 2016 (edited) Do petrol lupos have the switch on the clutch pedal or is that just the diesels? Tells ecu clutch pedal pressed and adjusts revs accordingly, also for cruise control disengage if fitted. In vcds it can tell when you press the clutch in or out. Is this only when clutch pressed or also sitting revving engine and it is slow to drop revs? Edited March 4, 2016 by Sausage not tellin Quote Link to comment Share on other sites More sharing options...
Sausage Posted March 5, 2016 Report Share Posted March 5, 2016 http://www.ebay.co.uk/itm/Clutch-Control-Switch-for-VOLKSWAGEN-Lupo-1-6-GTi-GTi-01-07-2005-Cambiare-/311329815125 Quote Link to comment Share on other sites More sharing options...
Ropers101 Posted March 5, 2016 Report Share Posted March 5, 2016 For me personally it's when the clutch is pressed. It's almost as if I've blipped the throttle while changing gear. Quote Link to comment Share on other sites More sharing options...
