Lee62 Posted August 24, 2015 Report Share Posted August 24, 2015 My gti alarm is driving me mad it's a factory alarm ,arm it with the key fob then 10 mins later or 2hrs later no telling off it goes same thing when I lock the door with the key, I've shut all the vents anybody had this problem and sorted it Quote Link to comment Share on other sites More sharing options...
Mr.Badbrains Posted August 25, 2015 Report Share Posted August 25, 2015 Might be a door microswitch related problem. Check if your dome light goes on and off like it should when you open and close the doors. Quote Link to comment Share on other sites More sharing options...
indie Posted August 25, 2015 Report Share Posted August 25, 2015 Yes possibly! I think they were both pretty duff though.Actually I have a feeling I killed them leaving them on the floor when I'm a 5-a-side footy. Can get a bit wet sometimes, so probably eventually fubar'd the remote! Works a treat now Quote Link to comment Share on other sites More sharing options...
carrera-gt Posted August 25, 2015 Report Share Posted August 25, 2015 Try turning off the volumetric sensor using the button just in case it's that, otherwise door microswitches are the likely culprit Quote Link to comment Share on other sites More sharing options...
Lee62 Posted August 25, 2015 Author Report Share Posted August 25, 2015 Thanks for the replies guys where do I find that microswitch Quote Link to comment Share on other sites More sharing options...
Lee62 Posted August 27, 2015 Author Report Share Posted August 27, 2015 Found old post Quote Link to comment Share on other sites More sharing options...
dirk1978 Posted September 7, 2015 Report Share Posted September 7, 2015 My alarm kept going off and it can be stopped by disabling the interior sensor with the button on the B pillar.So I vacuumed out the sensor, then disconnected and reconnected it a couple of times which seems to have helped. Quote Link to comment Share on other sites More sharing options...
carrera-gt Posted September 7, 2015 Report Share Posted September 7, 2015 You may want to replace the sensor, if it keeps doing it they do get old. Not sure how much but bound to be expensive from VW. Quote Link to comment Share on other sites More sharing options...
Rich Posted September 7, 2015 Report Share Posted September 7, 2015 You may want to replace the sensor, if it keeps doing it they do get old. Not sure how much but bound to be expensive from VW.common in the mk4 golf and pocket sized so they're pretty cheap really . . . . . .. Quote Link to comment Share on other sites More sharing options...
