yogibearboii Posted May 16, 2015 Report Share Posted May 16, 2015 Hi, I don't suppose anybody has had or knows how to resolve the issue I'm having with my dash/instrument lights. The issue is that it work normally when the side lights are selected but then does illuminate the speedo or anything when the main beam is selected (headlights work as normal). I have checked the fuses and they all look fine, any help will be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Skezza Posted May 17, 2015 Report Share Posted May 17, 2015 Sounds like a short or maybe a loose wire but my knowledge of foxes is next to nothing.First thing I'd do is disconnect the headlight switch and clean the plug generously with switch cleaner. Clean the socket as all. Reconnect it and make sure it's correctly plugged in and not loose. Go from there. Quote Link to comment Share on other sites More sharing options...
yogibearboii Posted May 17, 2015 Author Report Share Posted May 17, 2015 Sounds like a short or maybe a loose wire but my knowledge of foxes is next to nothing.First thing I'd do is disconnect the headlight switch and clean the plug generously with switch cleaner. Clean the socket as all. Reconnect it and make sure it's correctly plugged in and not loose. Go from there.Thanks Skezza, I will have a look into this, meanwhile if anybody else has an idea please let me know. Quote Link to comment Share on other sites More sharing options...
yogibearboii Posted May 19, 2015 Author Report Share Posted May 19, 2015 This has now been resolved by drowning the switch in switch cleaner and giving it a few twists! Quote Link to comment Share on other sites More sharing options...
Skezza Posted May 28, 2015 Report Share Posted May 28, 2015 This has now been resolved by drowning the switch in switch cleaner and giving it a few twists! Switch cleaner fixes everything Quote Link to comment Share on other sites More sharing options...
