dashboard warning lights
marybakers
my fox 1.2 hatchback has a steering wheel yellow light come on in the dashboard,has anyone any idea what the problem is,much appreciated if you can help,what lights should light up on the dashboard when you start the engine.thanks
Pretty sure that means the steering wheel might be out of line with the power steering servo or something. I forget what it is, but I know when changing the steering wheel, the solution is to full lock from one side to the other then central.
